This is not a measurement from my Microphone this a measurement of my High level inputs right before they reach my helix dsp. No acoustics, just electrical. I wired in a TRS stereo connector to my High level inputs and used my sound card to measure it. I wanted to see if my Factory headunit was outputting a full, flat signal. I played Pink noise from an app on my phone and a file I downloaded on my laptop, both produced the same results. That is the measurement at max volume but it did not seem to change the shape of the measurement at lower volumes.
I'm going to try to use the built in ISA as you suggested before. I had no idea it was even in here!
Cutaway: I believe the pink noise is supposed to appear flat in REW as the graph is split much more by octaves, not by frequency. if the graph was evenly distributed between 20hz-20khz then it should appear with a downward slant. Correct me if I'm wrong though, but all the other people in the link I posted tests showed pretty flat graphs. although I think they had aftermarket head units.
