I'm having issues getting my DSP to recognize G/H channel input as AUX source.
Running A/B channels from head unit with RCA splitting to output all channels, everything is OK.
Input to G/H is through a PC with outboard DAC (Audioquest Dragonfly Red) @ 2.1 Volt- confirmed that the DSP is set to correct input voltage via jumpers
I have the Helix DSP software set to recognize AUX as G/H on signal, with priority, and running a single volume knob set as master.
If I move the inputs from G/H to A/B I get sound but nothing from G/H. So that rules out the DAC signal.
I do have Aux input as overriding input preference.
Any thoughts on what I'm missing? In my other car I have a similar setup but using the Helix HEC and it works great. Thought I'd try an outboard DAC and it's not functioning the same.
TIA!
TIA!
