1 - 3 of 3 Posts
Is anybody familiar with this amp? It lists a wide voltage range, 11-15volts or so. My question is does it still produce 200x2 at a lower voltage, Like the JL Audio HD series or some Zapco amps do?? The description when reading about the M4 makes me think it will run at 11volts but the output will suffer
The M-FOUR has a regulated power supply so it will make the same power at any voltage within its range.
I thought that only the higher series amps are regulated. When i checked out the site, they only state that the c series, and the p/dsp series amps are fully regulated.but It does show that all of them can play at low voltage down to 6 volts, but again, the m series doesnt state full regulated like the rest. Why is that?.
1 - 3 of 3 Posts
