Couldn't find anything in here on it, so thought I'd share.
Yes Im the guy who brought it up on FB in 'that' SQ forum.
In a nutshell:
Helix's new DSP amp combo.. Highlights..
- Something close to DSP Pro processing quality in 8 channels
- 6-channel amp with actual power, unusual for such a piece
- Sub channels RCA out to a sub amp (processed).
- Optical input like their other DSP's
Badassness in one box.
Discuss...
P SIX DSP
The 6-channel amplifier P SIX DSP not only delivers loads of clean power and a top-notch DSP processor, it also comes with a completely new output stage concept that combines the benefits of class D amplifiers with the sound quality of class AB technology. Our unique “Class Ultra D” concept eliminates the negative influence of the indispensable output filters with a revolutionary concept that incorporates an analog feedback path back to the digital domain.
The result: Incredible damping factor (up to 1,000) even at 20 kHz, no load dependency of the frequency response and lowest possible THD for unparalleled sound quality. Almost needless to mention are the numerous input options including SPDIF optical and a HEC (HELIX Extension Card) slot for e.g. Bluetooth® audio streaming or other additional functions.
The P SIX DSP incorporates the same ultimate audio DSP with 64 Bit resolution and unbelievable processing power as HELIX DSP PRO. Two additional RCA outputs allow extending the system with external amplifiers up to eight processed channels. Despite this impressive bundle of engineering know-how the P SIX DSP shows up with a typical, clean design that has remained very compact for easiest integration.
FEATURES
New “Class Ultra D” concept which combines the sound quality of class AB technology with the benefits of class D amplifiers
Cutting-edge, extremely powerful “fixed point” Audio DSP with 64 Bit resolution and 1.2 billion MAC operations per second
Six speaker outputs with up to 215 Watts RMS into 2 Ohms
Two processed RCA outputs
Extremely high damping factor (> 1,000)
Inputs: 6 x RCA, 6 x Highlevel with up to 20V RMS input *sensitivity, optical SPDIF input
HELIX Extension Card slot (HEC) for additional input / output modules like Bluetooth® Audio Streaming
Compact design with low heat dissipation thanks to *extraordinary efficiency
SPECS
RMS power:
Measured acc. to CEA 2006-A
- Channel A - F @ 4 Ohms:120 Watts per channel (≤ 1% THD+N)
- Channel C - F @ 2 Ohms:215 Watts per channel (≤ 1% THD+N)
Inputs:
6 x RCA / Cinch
6 x Highlevel speaker input
1 x Optical SPDIF (12 - 96 kHz)
1 x Remote In
Input sensitivity:
RCA / Cinch 2 - 4 Volts or 4 - 8 Volts
Highlevel 5 - 10 Volts or 10 - 20 Volts
Outputs:
6 x Speaker
2 x RCA / Cinch
2 x Remote Out
Output voltage RCA:3 Volts RMS
Frequency response:20 Hz - 22,000 Hz
DSP resolution:64 Bit
DSP power:295 MHz 1.2 billion MAC operations per second
Sampling rate:48 kHz
Signal converters:
A/D: BurrBrown
D/A: BurrBrown
Signal-to-noise ratio
(A-weighted):105 dB (digital input) 100 dB (analog input)
Distortion (THD):< 0.01 %
Damping factor:> 1,000
Input impedance RCA / Cinch:64 kOhms
Input impedance highlevel:30 Ohms or 64 kOhms
Operating voltage:9.6 - 18 Volts (max. 5 sec. down to 6 Volts)
Additional features:Control Input, USB, HEC slot
Dimensions (H x W x D):50 x 250 x 190 mm / 1.97 x 9.84 x 7.48”
LINK
In a nutshell:
Discuss...
P SIX DSP
FEATURES
SPECS
RMS power:
Inputs:
6 x RCA / Cinch
1 x Remote In
Input sensitivity:
Outputs:
6 x Speaker
2 x RCA / Cinch
2 x Remote Out
Signal converters:
A/D: BurrBrown
D/A: BurrBrown
LINK
