1 - 19 of 19 Posts
Looking for someone to do some tuning to my system in NC or SC. Need to be fluent in the Helix software. Would need gains set correctly. Use of a oscilloscope would be a plus. Would need it RTA’ed for SQ with the most volume possible without distortion.. System consists of 4-super tweeters. 2-6.5 midrange 2-6.5 midbass 2-8” midrange and 2-10” midbass. Powered by 4 soundigital amplifiers. Any help or contacts would be great... thnx
I guess I'll start.
Ditch the super tweeters, 2 6.5 midbass, 2 8's, 2 10's, and 2 amps. Add some tweeters, and a sub or 2. Reevaluate your life, aim for realistic goals.
I don't care what you've got for drivers, you've got a Helix and you want your stuff to sound better. I can respect that.
I'm in Augusta, GA, and have O-scopes, RTAs, SysTune, and so on.
Bring it and I'll tune it.
John, you up up for this?
I see this might have been a waiste of my time based of a few responses. Nothing I listed can be changed and no subs can be added. As crazy as it is this system is on a motorcycle.
My doorcam caught you going by the other day, please turn down your radio sir.
You should have led with that. 6.5 mids will not play high enough to match up to super tweeters, if that's what they are, I'm thinking bullet type "super" tweeters, those might play low enough. The motorcycle explains the overkill with midbass drivers. Give us more info, especially about the tweeters.
Discussion Starter #14
The 6.5 midrange have a freq range of 150hz-12khz, The 8’s 130hz-10khz
The super tweeters are a bullet style that go in gauge holes or pods. The tweeters are prv tw400Ti-Nd-4. Freq response 4500-20khz
Umm... that seems unlikely that any of those would play that high. However, you may very well be able to meet up with the tweeters at 4500 hz, if the 6.5's are on-axis.
Discussion Starter #17
The 6.5 midrange are ground zero
High end midrange speaker with neodymium magnet
Durchmesser
165 mm / 6.5"
Belastbarkeit (RMS/max.)
200 / 400 Watts
Impedanz
4 Ohms
Effizienz
96 dB
Frequency Response
150 Hz – 12 kHz
Voice coil
38 mm / 1.5" CCA
Einbautiefe
68 mm
The 8's are
Durchmesser
200 mm / 8"
300 / 500 Watts
Impedanz
4 Ohms
Effizienz
98 dB
Frequency Response
130 Hz – 10 kHz
Voice coil
63 mm / 2.5" CCA
Einbautiefe
83 mm
Durchmesser
165 mm / 6.5"
200 / 400 Watts
Impedanz
4 Ohms
Effizienz
96 dB
Frequency Response
150 Hz – 12 kHz
Voice coil
38 mm / 1.5" CCA
Einbautiefe
68 mm
The 8's are
Durchmesser
200 mm / 8"
300 / 500 Watts
Impedanz
4 Ohms
Effizienz
98 dB
Frequency Response
130 Hz – 10 kHz
Voice coil
63 mm / 2.5" CCA
Einbautiefe
83 mm
Ok, I can't help with tuning a Helix, but you should probably start a new thread with a title like "need help tuning a Helix dsp on motorcycle". Because we clearly all thought you were some idiot fixated on midbass drivers, but the motorcycle part explains that overload of midbass, you actually NEED all of those. Maybe someone can help you out. Motorcycle audio is interesting, and probably frustrating.
1 - 19 of 19 Posts
