Hi all,
got some new 2-way compenent speakers with main speaker, tweeter and crossovers. Haven't got an amp just wiring them straight into the head unit. The cars previous speakers weren't plugged in by previous owner no idea why but may be because he had same problem not sure. Wired them in using crossovers correctly with them both being mirror images of eachother and right side didnt play/played v quietly whereas left was full volume and great. Pulled out the connector from door cleaned that, changed the clinch next to the headunit, nothing was fixing it so decided to wire straight from the crossover to the headunit, did this for both sides and it switched to playing out the other side only (the right) and barely anything coming out the left. Also switched the head unit to a spare and had the same result so don't think it's anything to do with that.
This proves both speakers work just not together no idea what i've done wrong as checked the way it's wired up and pos is pos and neg to neg etc so shouldn't be polarity. Can upload some pics if that helps. I'm not an expert but praying i'm just missing something obvious.
Thank you so much for any help you can give me!
