1 - 6 of 6 Posts
THIS IS GOING IN A 2004 CADILLAC SEVILLE SLS!!!
For subs i have made the decision to go with RE but i dont know whether to go with one 12 SX or 2 10's SE however i am leaning toward the pair of tens...i dont want anything obnoxiously loud but i do want to feel it w/out compromising sq...i was suggested by the RE Tech to build a ported box tuned low to be able to play loud and retain quality of the bass...
For the amp was thinking of US amps md.1dn
I went to a stereo shop and he said I shouldn't go w/sealed because w/big cars all the bass gets trapped in the trunk....suggested I build ported enclosure vented into the arm rest or rear deck...I don't want to do any major reconstruction but I was thinkin if I just remove the factory sub and use that open space as my vent to the trunk and whether ported or sealed I will have a way for the bass to travel into the cabin of my sedan.
So would my idea work for what I am trying to accomplish?
Are there any suggestions for mounting the amp under the rear deck?
THANKS FOR THE HELP
I'd recommend looking into a 6th order bandpass design ported through the factory sub hole in the rear deck.
My last car was a 2005 DTS, I believe the rear deck and trunk are similar, I went with a Fi Q15 sealed at 2.5 cubes just below the rear deck opening. Output was phenomenal, it actually cracked my windshield where the rearview mirror was mounted while I was doing my initial tuning.
Maybe an IDMAX would work in that situation [ sealed, or ported and tuned low ].
The benefit of the sub would be if it didn't get loud enough you could suspend it from the rear deck and go IB.
Thus playing into the cabin area !
I'd go with 2 10's ported. More cone area, plus less stress on your subs when you do wanna get loud.
What is IB??? (not good with all the jargon)
And Thanks for all of you guys suggestions i really plan on making this an investment not just a throw away project!!
1 - 6 of 6 Posts
