1 - 3 of 3 Posts
I have an Alpine IVAW205 for a head unit, I also have an Infinity Kappa One amp powering a JBL P1224 sub. I have had this amp for about a month now and really have enjoyed it. Today for some reason everytime I power the car down the sub pops! I called the Infinity tech support and ran through a couple of things w/ them b/f they decided that the amp is bad.. We are in the process of getting this unit replaced. After hanging up I later on in the evening I took the car for a ride and noticed that when I change the channel the sub also makes the same "pop" noise.... I really hope that this is a problem w/ the amp and not the deck!!
Thoughts!!!
unplug the RCA input and turn the system on and off and change the channel. IF the sub pops, it's the amp. If it doesn't, it's not the amp.
Can you connect an altrnate source to the amp ?
Can you switch the amp with a friend ?
TESTING will determine what it is ! ;)
1 - 3 of 3 Posts
