1 - 10 of 10 Posts
Im looking at adding to high output alternators on a 07 tahoe what all would i need to make this work right with out damaging my electric system and i will be adding a extra battery to what are some good brand alternators I'm looking at mechman right now thanks in advance
Mechman is the way to go for the HO Alternator. When purchasing batteries, make sure they're the same make & model. Finally, add 1/0 gauge Power Cable under the hood.
First off before we get to an alt, what amps, and what are you running?
Note: more then one battery is moot unless you play with your audio when your car is off.
Im running a jl hd 6004 and going to be running either the rockford fosgate t2500 or the mtx 4001 on either the rf t2 15s or the dd 9515 2 15s and i have dvd screens in the back of the head rest and a flip down and 2 dvd players and a convertor for playing xbox360 or ps3 and when i wire up the extra alt is there away that i should wire this up or and extra stuff that i need to install with it
You will need to replace your existing alt and replace it with a high output one.
K so would I be ok with just changing the factory alt out to a Ho alt would that be enough or should I run 2 Ho alt and do I need extra batteries
No one will be able to answer this question until you tell us what you are running... HU/AMPS/PROCESSORS/SUBS.....
You most likely only need one High Output alt unless you are installing an insain amount of gear.
Im running the pioneer avic 130 2 pairs of jl audio c5 6 1/2s and the jl audio hd 600/4 amp and 2 digital design 9515h subs and the rockford fosgate amp t2500-1bdcp or the mtx amp t4001d and i have 2 headrest screens and one 15in flip down screen and 2 dvd players and a convertor for power for a xbox360 or ps3
why do you have 2 DVD players?
Why would your converter (normally called a Power Inverter) only work for a Xbox360 or a PS3? Are you saying it would not power up an Wii or even an Atari 2600?
1 - 10 of 10 Posts
