I have 2 jl 12w7s I'm needing help on a box design it will be in a Tahoe with a Rockford t2500 amp running them I was thinking of something like the subs on top and a port in the back I have 48"w x 25"h x 36"l of space to work with I was thinking something around 4 or 5 cu. ft but not should how to tune the port this would be my first box build
Have you checked JL's website? They'll have a complete enclosure suggestion on the site.
25"H x 26" W x 16.11" D if using 18mm MDF, slot vent, same face as subs, 2" wide, height of box and 35.78" long. 7.278Cf total, tuned to 21.81Hz, F3 22.2Hz. Subsonic at 20Hz
Tuned for SQ (if you EQ out the hump) or streetbass if you're after big dirty low end.
Drop the port length down to 15" for 33Hz tuning, 6" for 44Hz. Raise subsonic to 25Hz/30Hz
If you can double skin the box, so 36mm MDF, increase the depth to 19.94" and change port length to 35.91" for the same 21.81Hz tuning.
