1 - 3 of 3 Posts
Hey everyone, I have put in many hours of research but still unclear on quite a few subjects. I'm Hoping some of you may guide me in the right direction! I have a 94 Honda Civic (2010 engine) Need help with the following plus more;
choosing an amp, how to get best SQ from A-pillars (Like On/Off Axis); Do you think I need to upgrade Alternator/Battery;please look to the bottom posts for future questions :) Thank you All!
HEADUNIT: Iphone
DAC: iStreamer
http://www.highresolutiontechnologies.com/pdf/HRT-iStreamer.pdf
MASTER VOLUME: JL Audio CL-RLC
JL Audio CL-RLC CleanSweep
PROCESSOR: JBL MS-8
JBL - MS-8 - System Integration Digital Processor
ACTIVE SETUP:
FRONTSTAGE: Hybrid Audio L4SE
AMP: JL Audio 300/4 (75 rms x 4)
MIDBASS(IN DOOR): JL Audio 6w3v4
AMP: JL Audio 300/4 (Bridged 150 rms x 2)
JL Audio 6W3v3 Subwoofers - Car Audio Subwoofers
REARSTAGE: Haven't decided if I will/can use one yet...
Amp: JL Audio 300/4 (From Fronstage) I'll use the other 2 Channels If I do.
SUBBASS: 2x JL Audio 12w7 (Ported)
Amp: ???
Contemplating between; JL Audio 1000/1(x2?), JL HD 1200/1, or JL HD 750/1 (x2) I'm leaning towards the two HD 750's. What do you guys think is best? Whats best for the money? I'll be able to run 4 amps with the MS-8 Correct?
How much Upgrading of the Battery/Alternator will I need for each Amp(s) Combo?
Thanks in advance for any help or advice! :)
Banned
what happened 3 years ago that called it off?
maybe ask a couple of questions about a couple of concerns, at a time?
like, what are you most worried about, with your feature set?
it's a lot to ask to have someone just mentally run through your component choices and point out obvious areas for extra attention.
1 - 3 of 3 Posts
