I assume that you have swapped sources and drivers to absolutely narrow down the problem to just the PPI amp?Hi guys. Made a few videos showing A/B tests of my amp to demonstrate the problem with this amp of mine.
I thought the same thing halfway through the first video. I had the volume set to OP's voice. Turned the volume up/down for music/narrator and defiinitely heard the distortion. Side note, the PPI sounded slightly thinner than the Soundstream. Could be bass boost, eq, room boundary, etc, but definitely a different frequency response in the open room with PPI amp.Either the mic isn't picking it up or my ears are not sensitive to what you are hearing. They sound pretty much the same to me.
Yes.Find someone with oscope
Right on thank you I'll give this a try.Grab a bottle of deoxit d5 and give the pots and switches a small spray in the slots/cracks (you'll have to open the amp to do it effectively). Work them all back and forth many many times. Wait a few hours.. do it again.
See if it makes a difference, it often does.
Looks like there's only 1 pot, no switches? Lol.. well odds arent as good that it'll help. If its just the one pot, grab deoxit f5 if you're going to go there.Right on thank you I'll give this a try.
Right on I'll keep this in mind and thanks again!Looks like there's only 1 pot, no switches? Lol.. well odds arent as good that it'll help. If its just the one pot, grab deoxit f5 if you're going to go there.
This was going to be my suggestion too.Grab a bottle of deoxit d5 and give the pots and switches a small spray in the slots/cracks (you'll have to open the amp to do it effectively). Work them all back and forth many many times. Wait a few hours.. do it again.
Yes I am. Thanks for the recommendation. I've gotten an offer from a well respected guy in the field who agreed to have a look. Will keep Shawn in mind though.I am not assuming that you are looking for this amplifier to be repaired but if you do Shawn King does amazing work. Sorry if you don't need this recommendation.
I believe Blessing God would be a much better approach than cursing Him 😊Hey guys thanks a lot for replies. Yeah, I've tried changing the gain but not necessarily while feeding it signal. Could be worth a try although the amp is disconnected again now in favor of the A204.2 that sounds like goddamned heaven. This problem has actually been pursued since I first noticed it in late 2016. The A600.2 has been on a few different setups. I'm not just examining this problem on this setup with this set of RCA's, this PSU, this source, etc.
So, part of my purpose of putting this post together was to try to get some other big names in the repair game to view and hopefully help to offer.
There's one that did, so I'm shipping it off as soon as I can get a box to fit it.
Yeah, aside from the distortion, this A600.2 does sound thinner than the Soundstream. That Soundstream is just brilliant. But the PPI has it's own character that I really enjoy. Very crisp on mids and highs especially when connected to my Soundstream speakers rated for like 100WRMS.
Just wish it didn't have the distortion. After about 2 days, it becomes easier to hear and makes the amp basically unusable.
