1 - 3 of 3 Posts
i have been running rf360.2 since six months .yesterday i was just tiding up the wires but i dont know what i did or was there wire shorting now my fr doesnot start.when ever i start the ignition the rf starts for a blink then turns off. if i disconnect the ground wire and then reconnect while keeping the ignition running it turns on and functions properly .but if i switch off the power and then switch it on .the rf does not turn off.
i am using rf to remote turn on the amps after changing the jumper .it was functioning well .
kindly help what can i do to rectify it.i am in india to sending to rf for repair is the last option
Hold the power connector tight against the unit while turning the power on at the key.
sir i have done that .once i have turned the power on .if i disconnect the earth from the chasis and then connect it rf functions .but keeping it connected to the chaisis .if i switch off the power and again turn on .rf does not turn on.it seems as it is going into some sort of protect mode
1 - 3 of 3 Posts
