1 - 2 of 2 Posts
I'm planning to do a 2way setup in a old-school merc 560SEC. Im planning to run ML280 tweeters and ML1600 midbass in kick panels. It takes effort to remove ECU and standing brake, but I think it is by far the best location.
Here is an example how it was done in a similar car.
http://www.cardomain.com/ride/540690/1988-mercedes-benz-s-class/page-3
I have no idea, how to determine how big enclosures should i make? My first choice would be to go sealed.
Parameters can be found here.
http://www.hertzaudiovideo.com/Doc/Hertz_Mille_TechSheet_ML_1600.pdf
Help anyone please :confused:
If i use this woofer box calculator http://www.diyaudioandvideo.com/Calculator/Box/
And parameters that are on official spec list:
Vas = 6.82 lts
fs = 71 Hz
Qts = 0.41
Qtc = 0.707
If gives me 0.12 cu ft or 3.46l box size. If i'm using data from the Kippel test on this website
Vas = 11.4264 lts
fs = 67.48 Hz
Qts = 0.4079
Qtc = 0.707
I'm getting a larger box at 0.2 cu ft or 5.7 liters.
Am i on correct trac?
1 - 2 of 2 Posts
