1 - 2 of 2 Posts
Hi guys, Im gonna be installing my 170 amp alt in my 1990 civic si.
My stock alt is 60 amp with a fuse of 60.
Is it necessary to change the fuse with a higher 170 amp fuse in the fusebox ? ?
heres a reference pic of a civic underhood fusebox. Which one do I replace ?
In the fuse box, you wouldn't change a thing... Only if the alt. ran through there to the battery would you consider changing anything.. Usually (I don't know hondas well) the alt runs to the batt and then to the car fuse panel..
1 - 2 of 2 Posts
