21 - 26 of 26 Posts
Discussion Starter #21
Sweet! I'm not crazy!
oh no, lets not get it twisted.. you absolutely are crazy, but what you are hearing is what you guessed <img src="http://www.diymobileaudio.com/forum/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Ok I conceded but at least I'm not hearing things that arent there, yet.
Discussion Starter #22
Now that I'm thinking about it, this could be used to phase align subs for people that dont have phase or ta control.
You could put the filter low and use different slopes to bring the phase around giving a much more coherent blend.
Is there a way to apply the HP filter to all output channels?... Like on the input side of the DSP? So the phase shift is equal on all drivers.
in the helix? You only get a high pass and a low pass. But you also have first and second order all pass filters to work with as well as delays which should take care of the issue. Or just build your sub setup to not need a subsonic :p
Sure it can be remedied with APFs or adjusting delays but why try mess'n with all that when applying the SS HP on the input (affecting all outputs) is a one and done remedy :)
I'd rather just not need to use a hpf on the subs lol. Also, there are no crossovers on the inputs
21 - 26 of 26 Posts
