Hello All, I am currently working on an audio upgrade for my '22 Honda Ridgeline RTL-E. After installing all of the gear, I am unable to get my gains turned up to a level where my music is loud enough without the noise floor becoming present... creating an audible hissing. This hissing is purely created when turning up and down the gains on the equipment and is not changed with source volume (factory head unit). Additionally, there is no buzzing or engine whining. Just a hissing noise floor.
The following is the gear that I have installed:
Here is what I have done so far:
I have set up the Kicker Key LOC according to their manual. When setting up the LOC, it requires a "gain matching" track to be played and the input gain is set via that process. During this phase I am only able to turn up the input gain to about 5-10% when the lights begin to flash indicating clipping I assume... This happens when the headunit volume is at 15/25/30 out of 40 it doesn't matter. I have tried to turn the factory headunit up over 30 and it begins to audibly clip with popping and crackles from the tweeters. Therefore, I am left with low-ish input voltage (~8V) that I am then trying to boost to a usable level on the backend. The LOC is a 4:11 converter. With the input side set just under clipping via the gain-match processes, and the output gain on the Kicker LOC at ~10% (The point before the hissing is very audible) I am only getting ~2.5V out of the LOC. This gives me enough to work with on my DSP/amp but again it is a battle between bringing up the gains to get reasonable volume without raising the noise floor too much.
After reprogramming the LOC over and over at different source unit levels and input gain settings, I am still left with a high noise floor when gains are turned up enough for a peak listening volume of I would guess (85-90 dB).
I then checked my ground for high resistance. My amplifier, DSP, and LOC are all grounded at the same point. I wire wheeled the paint down to get bare metal but it still has a resistance of 1 Ohm to the battery. My long test leads measured at 0.3 Ohms and the reading was 1.3 Ohms between the negative battery post and my grounding point at the factory power inverter.
Finally, I started unplugging RCA cables and the hissing subsides when I unplug the LOC from the DSP leading me to believe that the LOC or the factory headunit/amp is the source of the hissing. I have tried adding a PAC SNI-1 signal noise reducer inline between the Key LOC and the DSP 408 and it made zero difference.
I have read quite a few posts on this forum discussing high noise floor issues with the Kicker Key products. I will say that the hissing is worse with the auto EQ enabled, because it is boosting the gnarly high frequency roll-off of the factory system EQ. However, none of these issues on other forum posts discuss the KEYLOC specifically. I have also read about people struggling with noise floor hissing with the JL Fix 82/86 in other Honda amplified systems.
I have considered running line level direct to the DSP 408 to see if the hissing persists but I would like to avoid rewiring my amp rack if possible. I could even go speaker level direct to the RD900/5 but running this system without an ability to adjust EQ is an absolute no-go for me.
Lastly, I should add that this is with the gains on my JL RD900/5 at zero - 1/4. Increasing the gains just brings up the noise floor. I have unplugged everything from amp and increased gains to max on the amp and I get a miniscule amount of noise floor increase to the point of being almost non-audible telling me that it is not the amp producing the hissing. I also had this amp in a previous install with an aftermarket head unit and it was silent.
With all that being said, here are the questions that I am left stumped over after calling both Kicker and Crutchfield tech support:
Is my ground with a resistance of 1 Ohm between the (-) post of the battery and my grounding point too much? If so, where have others found successful grounding points with a resistance of less than 1 Ohm? Others on the Ridgeline forum have utilized this same spot with good results. Would a big 3 upgrade help?
Does the factory amplifier need to be loaded with a resistive level lower than 60 Ohms (this is the load built into the LOC) for it to produce a signal with low noise floor like factory?
Are there any suggestions that you all might have?
Here is a photo of my amp rack and how it is wired to clear up anything I may have missed:
Thank you for your time and help... it is greatly appreciated!
- Kicker Key LOC (grabbing signal at the factory amp via driver/passenger door speaker outputs)
- Dayton Audio DSP 408 (2 channels in from Key LOC with 6 channels out)
- JL Audio RD900/5 (6 channels from DSP - 1/2: tweeters, 3/4 woofers, 5/6 Sub
- Kenwood XR1701p (running bi-amped through factory x-overs, utilizing speed wire to run outputs up to factory harness in passenger kick panel)
- Factory ANC module removed
