61 - 75 of 75 Posts
It helps to solder small things under good magnification.
The exact reason I invested in a good quality microscope for my home lab. It cost me over $1000 but has come in real handy the past 15 years.
Reactions: stegmsk
Discussion Starter #63
Hands with age or from constant tool/coupling vibrations is an issue for tradesmen. My hands at 41 can quiver if I were to hold them up to show steady or not. Those are working hands and probably a fair bit older than mine. You earn the shake. I bet we are all mostly solder suckers! haha
My day job is really brutal on my body I lift constantly and I think some of my shaking is inherited normally when I do intricate things i try and rest my forearms on something for stability.
I may have missed one of your comments. But, why did you remove the power transistors? Be careful soldering those back in. You don't want to damage your PCB's.
Discussion Starter #67
They weren't located very well so I'm going to precisely locate them when I'd do final assembly. there is a ledge that is machined on the heatsink and the clamping bars will have slots. I will resolder once the transitors are clamped into place.
Discussion Starter #70
I have maybe a dumb question with the RCA cable would it be better to ground the shield to the RCA ground wire or the chassis or is the chassis a bad idea since the power supply is going to be grounded the the chassis.
Discussion Starter #73
progress will be a little bit slow on this I'm getting worked to death at my job right now. I've been to tired to do much of anything. I think Honda is trying to kill me.
61 - 75 of 75 Posts
