1 - 7 of 7 Posts
Built this from scratch awhile ago and just looking for some opinions. It has a dual spider suspension, of which I built both by machining dies to form them. I machined the voice coil out of titanium which is in a machined piece of Delrin (Acetal Resin). I also machined the whole body/basket out of aluminum. Lastly, I machined the motor structure out of low-carbon steel. All of this machining was performed using manual machinery.
Specs: 3" mid-range/tweeter, about 1/2 ohm (this was done by accident since the wire wasn't properly measured before it was wrapped). Unfortunately due to the low impedance I haven't had a chance to play this often, but it does function according to the tests I performed after building it.
Any feedback you guys have would be great. Thanks!
What material are the spiders formed from? Also curious about your coil winding procedure and the voice coil binder glue you used.
The spiders are cotton like from a shirt and expanding gorilla glue with plastic rap to prevent it from sticking to the die and I used my lathe to wind the wire and epoxy to hold it
Interesting. I tried DIY coil winding a few years ago on my mini lathe by making some mandrels and mounting a spool with adjustable tension to the toolpost. I didn't have a feed rate that matched the wire size I was using so I couldn't get a tight wind without overlapping. Here's the bonder I used: Voice Coil Bonder 360-Black - 1 Quart Can
Very cool!
I'm also in the process of making tweeters I'll be making every thing on them except the diaphragms I'll post pictures when I Finnish making everything
1 - 7 of 7 Posts
