A DMM would be worth the 10-15$.
Is the sub a dual VC? And is so how is is it wired?
What is the impedance of the sub?
What impedance can the amp supply?
And what impedance is the amp rated as supplying in Bridgedmode?
If it is wired in parallel, I would just wire the sub in series, and set the gain to something sensible.
He will either blow the amp or the sub at some point. But the amp sound like it has some protection. Wiring the sub in parallel could easily get the amp turned up into the range of clipping... whether a DMM or ears are better for that is an endless debate.
You could also use the DMM to check the sub's impedance.
