have you tried winISD or the like to get an idea?
keep in mind the enclosure plays the most important role here...
Please...please tell me your joking...Set to normal. (12:00)
I hurt my pancreas laughing again.xmax during what? music? test tones? audiobooks? seems pretty hard (and useless) to try and quantify or aim for an exact xmax when music is inherently dynamic and the volume knob is constantly changing
if you are unhappy with the current performance of your system, which all these useless questions suggest you are, calculator dick slapping will not change the things about your JL's you don't like (I'm guessing lack of midbass)
however taking everyone's advice when you made the driver selection (which you did not) would have yielded a better choice for your situation and a driver with better midbass performance in the first place (cough SLS8 cough)
Not the first time; not the last. Good try. Seriously, who are you and why are you doing this to our forum? *cat pix r strong wit thiz one*
again, peak during what, music? a farting noise burned on a cd? 'this american life' on the radio? how are you getting that number without using test equipment on your amplifier to verify its output? and how long of a 'peak' are you talking about? 5ms? 100ms? 3 hours?I'm talking about "peak" transient here. How do I determine what wattage point the xmax is reached by say 50Hz in an IB enclosure? Right now I've set a peak of 175-watts. I'm just wondering if I could use more wattage on these midbasses. It doesn't hurt to have more power if I can use it.
You're about as brilliant as tspence, apparently. My point in the other thread was that his posts in that thread weren't really all that awful, yet he was continually berated because he is tspence.and where's squeak9798 to defend spence? This is all junior high pedantics, right?![]()
I'm not so much defending him as I am pointing out how moronic you guys are for always chasing him around and bashing him at every opportunity.But seriously how the **** could ANYONE defend this guy?
I used a 0db tone with a multi-meter for 50Hz, 60Hz, 70Hz, etc. I verified it didn't get anymore than 26.4 volts even with the highpass and lowpass filters on.What do you expect to gain by knowing how much power it takes for this mid to reach it's mechanical limit at 50hz?
How did you determine that you have setup the amp now to give the mid 175 watts at 50hz?
You probably won't take this advice, but here's what I do. I set the gain on the midbass, or mid in a 3 way front stage, specifically the Infinity mid in your case, with an average level recording to get the maximum undistorted output near, but not at the volume controls maximum (to leave some volume adjustment for lower level recordings).I used a 0db tone with a multi-meter for 50Hz, 60Hz, 70Hz, etc. I verified it didn't get anymore than 26.4 volts even with the highpass and lowpass filters on.
The reason for determining the mechanical limit is so that I can maintain/push the limit of the driver and keep mechanical distortion as low as possible.
Considering how low they're crossed I'd say the JL's are definitely the weak link as far as maximum output is concerned.Now, if the JL's are the weak link, although I doubt it, well then you're going to have to bring everything else down to it's safe level.
