1 - 5 of 5 Posts
I bought a couple of these short RCA bridging splitters:
But unfortunately they are too loose; they easily slide off with the slightest tug. I'm pretty sure that a static sound I occasionally hear is due to the cables rattling when going over bumps.
They seem to be high quality overall, and I can't find any other bridging cables in that size. So I'd like to tighten them if possible. But I don't want to just squeeze the sleeves together because that will make them oval shaped and reduce contact area.
Should I return them, and if so does anyone have recommendations for short bridging splitters (ideally about 2 feet total length)?
Or is there some sort of tool that can tighten the sleeves into smaller rounds, by applying pressure evenly around the whole circumfrence? I would love to learn how to tighten cables if there is a way.
carefully bending them in a little from each side is the way to tightening them. It may take them a little out of round, but then when you plug them in, there will be enough tension on all sides that you will be fine.
Thanks all. Using pliers on the outside of the sleeve worked well. As @miniSQ and @Thomasluke7899 say, just a little bit of pressure is all that was needed. Now they are nice and tight.
Before I wised up and followed your advice, I tried pushing the sleeves down a funnel, figuring that would squeeze them round. But for whatever reason that didn't tighten them.
1 - 5 of 5 Posts
