1 - 2 of 2 Posts
Hey thanks for looking, as the title says, I can't find the option in the setting to switch on the steering wheel controls. I must point out i haven't connected the interface (3.5mm jack) yet, is it possible they will appear once the adapter is plugged in? I'd rather not pull the center console apart to find out it doesn't support the function.
Thank for any advice in advance, it's appreciated
The steering wheel controls will work once you connect the SWC interface module. Just RTFM and follow the directions from the interface manufacturer to install the SWC module. Easy peasy.
There is no setting in the HU to enable it. It "just works" once you connect the SWC interface properly.
1 - 2 of 2 Posts
