1 - 20 of 56 Posts
Hybrid Audio Technologies Clarus C51-2 Review
As promised, here is my initial review of the Hybrid Audio Clarus C51-2 set.
I will divide the review into the following sections:
1.Initial Impression,
2.Install Details,
3.Listening Thoughts
Let’s get started…
Initial Impression
When I opened the box and started inspecting the contents I found that the Clarus line is very similar to the Legatia line that was first released by Hybrid Audio Technologies (HAT). The build quality of the midbass drivers are quite nice. Cast basket, woven speaker leads, inverted surround and a paper cone. I am VERY partial to paper cones. I feel they render music the way the artist intended. The tweeters are nice also. Very small, so they should be easy to install - and they are. Now for the crossovers… I LIKE THESE CROSSOVERS ! They are very well made and would be welcome to show off in any system. The components used in the network are topnotch. You also get grills and install items…
Install Details
Well these went in my daily driver, 2001 Accord LX, in the factory locations. Midbass in the doors and the tweeters in the dash openings. The crossovers were left under the seat, for now. Power is supplied by an Xtant x603. No subwoofer is used because the Xtant’s sub channel is not functional right now… Repair is on the horizon… When the Xtant is repaired I will be using a DIYMA12 in a ported enclosure.
Listening Impressions
Here is the music I listened to during my session:
4.James Taylor “Gaia” on Hourglass album
5.Keb Mo “Grandma’s Hands”
6.Jennifer Warnes “Joan of Arc” from Famous Blue Raincoat
7.Metallica “No Leaf Clover” from S&M
Gaia
This album from James Taylor is wonderful and this cut is one the best on it. The recording is very open and spacious. I love James’ voice and the Clarus set reproduce the recording in such a true way. The soundstage is very wide and pretty deep. This set is smooth, very easy to listen to although a sub is needed for the lowest tones. Remember the set is installed in factory locations with no damping.
Grandma’s Hands
Keb Mo’s recording of this song is wonderfully simple. I felt like I was sitting on the porch of an old general store with Keb Mo while he was performing the song. So detailed and REAL ! On a good system you can hear a broomstick being used for rhythm in the background. With the Clarus set, you not only hear the broomstick you get a wonderful sense of depth. Phenomenal !
Joan of Arc
This is one of my GO TO cuts when evaluating a sound system. Jennifer’s voice is simply pure. That is the best way I can describe the way the Clarus set reproduced this recording… PURE. Or should I say Purely Beautiful. The set proved to be very powerful, able to take soft passages and build into wonderfully complex reproductions that gave me chills. When Leonard Cohen joins in his deep vocals are rendered in a visceral manner. Considering these midbass’ are only 5.25” drivers… I am highly impressed. Loving this set !
No Leaf Clover
OK up to now my musical selections have been rather “highbrow” and “elitist”. This selection represents what I love to listen to just for my ride home each day…. Metallica’s S & M album is one of my favorites. Anytime classical and metal is fused together it only brings about good things…! This selection is very complex and dynamic, the Clarus set did a GREAT job of reproducing this. As I stated earlier, the set does need a subwoofer.
My summery …
I love this set of speakers. I had the opportunity to use Hybrid Audio’s Legatia speakers and found them to be World Class, the Clarus are right there also. They are extremely detailed, smooth and have dynamic capabilities. If you want a speaker system for a daily driver or even a casual competition system… RUN don’t walk to your nearest Hybrid Audio Technologies dealer. The best system I ever used was a Dynaudio 2-way setup powered by a Butler Tube Driver. I loved that setup…. Hummm,,, now where did I put those Tube Drivers….?
can't believe i missed this review 4 days ago.
i use legatia drivers in my car and a 6.5" clarus set in my wife's car.
i would say your review of the clarus set is spot on. great set!
curious - you say no matting... are there holes in the inner skin of the doors? if so - seal those up bare minimum and your low end should improve dramatically. you will still need a sub, but the midbass will be killer. (yes, i said KILLER midbass - even w/ the 5.25" set)
Discussion Starter #12
azngotskills:
Frankly...
I love Dynaudio, always have... Compared to the Hybrid Audio set, they sound a bit lifeless...
I like the Clarus set that much... I'm considering going up the food chain to the 6" Clarus set...
J
I don't know if you did much research with this but would you say that on or off-axis presented a more realistic response from the clarus drivers?
Also, I believe that you said that you had used Legatia drivers before so what is your response for them better on or off-axis?
Benny or anyone please feel free to respond Thanks guys
i have the clarus set installed off-axis in the doors of my wife's mazda 3. did not experiment with them any other way, as i wanted to try them as they are billed - "plug and play" in the oem locations.
and they are great that way. no complaints!
the l3 mids and l1 tweeters in my car are aimed on axis directly at each corresponding ear. l8s are off axis in the doors, but they are only playing up to 150hz. as with the clarus set, i have not tried them any other way. sorry! :) i knew this was a proven setup, so i just went for it. i have read great things about them off axis, too, though.
azngotskills:
Frankly...
J
Wow the Dyn's are lifeless? That is a pretty big statement. I would like to experiment with these drivers. I am curious now. They must perform pretty darn well for someone who loves Dyn's to say these make them sound lifeless. I may need to get my hands on a set just to try out.
In stock - no waiting :)
http://www.12velectronics.com/servlet/the-Hybrid-Audio-Technologies-cln-Clarus&trade-scln-/Categories
I don't think you will just be "trying them out" once you hear them.
I recently got to listen to a Legatia set. I find it necessary to audition anything that receives attention, especially when it's being compared to the likes of Dyn.
My personal opinion is that Hybrid's stuff trys to act more high end than it actually performs. Especially for the price tag.
There was some distortion, especially when the speakers were pushed a bit. Overall clarity was a bit clouded, among other things. It lacked dynamism, and impact. Basically, the things you look for or expect in a high end set.
Then again, they were stacked up against a Dyn car Esotec 362, a DLS 8.3i car, and a Rainbow car Cal28 tweet and 6.5 kick, not exactly easy competition. Installs varied from kicks to A-pillars, but either way, I wouldn't place the Legatia's even close to these cars, in any regard.
I would be as bold to say the Hybrid equipment fell on it's face. Especially next to Dyn equipment.
The Legatia drivers remind me more of Vifa drivers. I'd personally do a DIY build with ScanSpeak or the alike to save some coin, and yield similar or better results.
Let your ears be the judge. Luckily for me, I am able to do A/B comparisions using high end gear, which gives a more accurate experience.
1 - 20 of 56 Posts
