1 - 3 of 3 Posts
Product Brand & Model: Hybrid Audio Technologies Special Edition Legatia 3 way component
Condition of all items: very light play with only a few hours on them so basically new in excellent condition
Total Price: : $1750.00
Shipping Terms: : Shipping through USPS unless otherwise noted. $15.00 with tracking
The Legatia L8SE speaker is based off the very successful Stage III L8 transducer, and the revised version 2 of the L8 known as L8V2. The first Gen L8 was launched in 2007 to car audio competitors, enthusiasts and audiophiles. In the years since the L8 mid bass has been included in many International Auto Sound challenge Association, national and world championship vehicles. The second gen L8V2 was launched in 2010. When it came time to enhance the L8 and the L8V2 the mid bass capabilities were taken highly into consideration and had three general objectives: 1) enhance the L8 and L8V2's ability to reproduce a wider frequency spectrum for possible application as a dedicated midrange in a two-way application. 2) to maintain if not enhance the L8's lower octave authority and impulse response through more displacement and lighter moving mass. 3) to improve motor compliance and inductance through the use of double-stacked N48H grade neodymium magnet and through the use of inductance rings.
Specs:
Overall diameter: 8.85 inch
Mounting depth: 94mm
Bolt center diameter: 211 mm
Mounting hole: 186mm
Recommended Minimum Crossover Frequency: 40 hz @ 24 db/octave highpass
Pnom Rated Power input ( no crossover): 90 watts
Pmax Rated Power Input ( no crossover) : 180 watt
Pmax with crossover: 240 watts
Frequency range: 40 hz-3800 hz +/- 3 db
Sensitivity: 89 db @ 1 watt
Mrms: 30g
Cms: 433 um
BL: 5.997
Voice coil diameter: 35.55 mm ( 1.4 inch)
Impedance: 4K
DC Resistance: 3.4K
Fs: 41.5 hz
Qms: 1.996
Qes: 0.914
Qts: 0.627
Xmax: 9.5mm(one way)
Vas: 27.5L
le: 36 uH
Sd: 0.02 m2
Legatia L4SE Mid range is based off of very successful Stage III Legatia L4 transducer which was first launched in 2007 and has been in many audio competitions.
-Overall Diameter: 4.65"
Mounting depth: 56mm
Bolt Circle Diameter: 109.5 mm
Mounting Hole: 94.5 mm
Recommended Minimum Crossover Frequency : 140 hz @ 24db
Pnon Rated Power Input ( no crossover): 35 watts
Pmax Rated Power Input ( no crossover) : 70 watts
Pmax ( with recommended minimum crossover) : 150 watts
Frequency range: 92 hz-18,000 hz, +/- 3 db
sensitivity: 87.3 db @ 1 watt
Mms: 3.632 g
Cms: 821 um
BL: 3.19
Voice coil diameter: 25.5mm ( 1 inch)
Impedance: 4K
DC Resistance: 3.2 K
Fs: 92 hz
Qms: 3.795
Qes: 0.661
Qts: 0.563
Xmax: 3mm
Vas: 2.95
Le: 7.1 uH
Sd: 5027 mm2
L1 pro SE Tweeter
Overall Diameter: 58mm
Mounting depth: 30.5 mm from bottom of surface mount flange
Mounting Methodology: surface mount tweeter with standard pitch M46 X 8 mm thick knurled thread aluminum adapter to secure the tweeter body from the rear
Construction: solid machined aluminum with polypropylene tuning chamber
Distortion: 5% max at rated power input , no crossover
Magnet Diameter and Construction: 24.5 x 3.5
Recommended Minimum Crossover Frequency: 1800 hz @ 24 db
Pnom: rated power input no crossover: 25 watts
Pmax: max power input no crossover: 125 watts
Resonance Frequency: 580 hz
Frequency range: fs (580 hz)- 40,000 hz
Sensitivity: 91.5 db @1 watt
Nominal Impedance: 4 ohm
DC Resistance: 3 ohm
Voice coil diameter: 25mm
Q Mechanical system: 1.244
Q Electrical system: 1.717
Q Total system: 0.721
Krm: 3.048
Erm: 1.001
Kxm: 4.314 mh
Exm: 0.409
Legatia L3X Crossovers
These have been specifically designed to work with any wide bandwidth Hybrid mid range. They are very attractive , high performance filter set that contains hand matched high quality low tolerance parts such as metalized polypropylene capacitors , air core low ESR inductors and low tolerance ceramic resistors. Also included is an industry standard tweeter protection circuit to defend the Legatia tweeters from being over driven or form faulty amplifier circuitry and extreme imput voltage. Circuit is double sided design with nickel plated spring loaded terminals for ease of install and adjustment of tweeter attenuation.
1 - 3 of 3 Posts
