Hybrid Audio Tech. Clarus C61-2 - $335.00 (GREAT Cond.)
Product Brand & Model: Hybrid Audio Technologies - Clarus C61-2 (Used in GREAT Condition)
Condition of all items: This is a set of Clarus C61-2. These speaker set was used and well taking care of and maintained. The box was put away and never touched nor damaged. Check the pictures just to see the condition of the whole box. You will need to get your own speaker wire and mounting screws. But outside of that. This is a component set that will take on anyone.
Total Price: $335.00 - Firm. Check my itrader and send a personal message for the quickest response.
Shipping Terms: Shipping is included to the lower 48 states. International shipping, send private message to make arrangements.
Pictures: See attached.
Clarus System Specifications
Frequency Response50Hz-22KHz +/-3dB
Efficiency 2.83 V/ 1 meter 93.6 dB
Continuous Power Handling (transient music input) 120 watts
Peak Power Handling (musical transient peak power handling) 250 watts
Recommended Power Range 25-175 watts
Nominal Impedance 4Ω
Thiele/Small Parameters
Overall Diameter Φ166 mm
Mounting Depth 78.5 mm
Bolt Circle Diameter Φ156.5mm
Mounting Hole Φ143.5 mm
Recommended Minimum Highpass
Crossover Frequency (fourth order) 45 Hz
Pnom Rated Power Input (No Crossover) 60 watts
Pmax Rated Power Input (No Crossover) 120 watts
Frequency Range of mid-bass driver alone (not including tweeter device) 50-9,000 Hz +/- 3 dB
