1 - 14 of 14 Posts
Product Brand & Model: Hybrid Audio Technologies - L3v2
Condition of all items: Open box with new Speakers and a slightly damaged box with no affect on the contents within the box.
Total Price:$260.00
Shipping Terms: Free to lower 48 States. Send personal message if international shipping is needed.
Pictures: See Attached
Online Information
The Legatia L3V2 is a 93mm (3.7-inch) “small format” wide-bandwidth midrange/full-range driver to compliment both two-way and three-way system designs, where a point-source midrange and/or fullrange driver is required. The following are the L3V2’s design attributes:
Thiele/Small Parameters
Overall Diameter 93 mm (3.7-inch)
Mounting Depth 43 mm
Mounting Hole 74 mm
Recommended Minimum Crossover Frequency 185 Hz at 24 dB/octave highpass
Pnom Rated Power Input (No Crossover) 25 watts (AES Standard)
Pmax Rated Power Input (No Crossover) 50 watts (AES Standard)
Pmax (With Recommended Minimum Crossover) 125 watts
Frequency Range 113 Hz – 18,000 Hz, +/- 3 dB
Sensitivity 88.6 dB at 2.83V/1meter
Voice Coil Diameter 25.5 mm (1-inch)
Impedance 4
Fs 113 Hz (free air)
Xmax 3 mm (one way)
Vas 0.96 L
1 - 14 of 14 Posts
