1 - 20 of 26 Posts
Hybrid Audio Technologies, Imagine I6SW, Legatia L3v2, Legatia L6SE
1.Two Imagine I6SW Subwoofer
2.Legatia L3v2
3.Legatia L6SE
All items are used
1.Imagine I6SW Subwoofer $250.00 for both, lowered price to $200.00 for Both
2.Legatia L3v2 $225.00
3.Legatia L6SE $500.00
shipping is $20.00 for each item
Shipping lower 48 states only
PayPal only
Imagine I6SW Parameter
Overall Diameter 168 mm (6.6-inch)
Mounting Depth 85 mm
Bolt Circle Diameter 160 mm
Mounting Hole 148 mm
Pnom Rated Power Input 125 watts
Pmax Rated Power Input 250 watts
Frequency Range† 32Hz-800Hz, +/-3dB
Efficiency 2.83V/1 meter 90 dB
Mms 39.7 g
Cms 435.75 μM/N
BL 13.8 T*m
Voice Coil Diameter 50mm (2-inch)
Impedance 4
DC Resistance 3.9
Fs 38 Hz
Qms 7.7
Qes 0.18
Qts 0.17
Xmax 12mm (two-way)
Vas 9.6 L
Le 1.42 mH
Sd 12,469 mm2
Legatia L3V2
Thiele/Small Parameters
Overall Diameter f93 mm (3.7-inch)
Mounting Depth 43 mm
Bolt Circle Diameter f84.5 mm
Mounting Hole f74 mm
Recommended Minimum Crossover Frequency 185 Hz at 24 dB/octave highpass
Pnom Rated Power Input (No Crossover) 25 watts (AES Standard)
Pmax Rated Power Input (No Crossover) 50 watts (AES Standard)
Pmax (With Recommended Minimum Crossover) 125 watts
Frequency Range 113 Hz – 18,000 Hz, +/- 3 dB
Sensitivity 88.6 dB at 2.83V/1meter
Mms 2.65 g
Cms 743 um/N
BL 3.277 T*m
Voice Coil Diameter 25.5 mm (1-inch)
Impedance 4
DC Resistance 3.4
Fs 113 Hz (free air)
Qms 2.766
Qes 0.598
Qts 0.492
Xmax 3 mm (one way)
Vas 0.96 L
Sd 3,019 mm2.
Legatia L6SE Thiele-Small Parameters
Overall Diameter
181 mm (7.1-inch)
Mounting Depth
78 mm
167.5 mm
Mounting Hole
146 mm
50 Hz at 24 dB/octave highpass
75 watts (AES Standard)
150 watts (AES Standard)
200 watts
Frequency Range
51 Hz – 10,500 Hz, +/- 3 dB
Sensitivity
89 dB at 1 watt/1meter
Mms
13.446 g
Cms
721.580 um/N
BL
4.898 T*m
Voice Coil Diameter
35.55 mm (1.4-inch)
Impedance
4 Ω
DC Resistance
3.4 Ω
Fs
51 Hz (free air)
Qms
1.941
Qes
0.612
Qts
0.466
Xmax
8.5 mm (one way)
Vas
18.613 L
Sd
13478 mm2
1.Imagine I6SW Subwoofer $200.00 for both
2.Legatia L3v2 $225.00, lowered price to $200.00
3.Legatia L6SE $500.00, lowered price to $450.00
1.Imagine I6SW Subwoofer $200.00 for both SOLD
Still have the L3V2 and L6S
Make me a reasonable offer
Discussion Starter #12
Re: Hybrid Audio Technologies priced dropped
1.Two Imagine I6SW Subwoofer (Sold)
2.Legatia L3v2
3.Legatia L6SE
All items are used
1.Imagine I6SW Subwoofer $250.00 for both, lowered price to $200.00 for Both (Sold)
2.Legatia L3v2 $225.00 Priced dropped to $175.00
3.Legatia L6SE $500.00 Price dropped to $400.00
PayPal only
Hey Jeff,
I have a new HAT Clarus C61-2 component set...still in the box. (I bought two sets, and only used one.)
Would you be interested in a trade?
Edit: I said "New"...I should have said they are a "Demoed" set. (Bought from Huckleberry)
Discussion Starter #16
Hey Jeff,
What was you wanting to trade?
Looking at your L6SE...
No biggie...nothing I have has even being powered up yet...still building.
The SE line is what I'd like to use for the quality, as well as the look.
1 - 20 of 26 Posts
