Above the big dip , the 1st comb in the responceHow can you be above a comb filter as it always has multiples of the lowest freq comb filter by nature? So if you have a dip at 500hz you’ll have one at 1khz, 2khz, 4khz etc and peaks in the middle, putting them as close to the screen/dash as you have done raises the comb filter to above the usable range, you can’t avoid a low down comb filter
and the focal has the same off axis response as any other driver that size…
The deep one that is the most problematic usually with off axis midrange in an a pillar configuration
Of course there’s multiples….. the big one is connected to width of car….. iirc
Above that there still dips and peaks , not as severe
But it ended up not being a issue. So meh
