I've made the ultimate, disabled-install friendly system. By disabled-install friendly I mean simply that I've destroyed my back this time so each subsequent tinkerings will be simple and easy
The bottom set of stacked Sinfoni''s aren't crooked, they are actually out and that's a poor picture. Installed correctly it is what you see only straight.
This isn't in the install section simply because I have no plan...I just wanted to make something
I believe a center channel will be an improvement. I own a deck with PL2 processing but am not going to use it. I've done the research and know how to do it all...just lacking inspiration at the moment to buy something (read: no money).
I hooked it up to the CDA 9887 Left Sub out, usually left blank. Audyssey fixes frequency errors and blah blah...I figured there was a slight chance that it was a summed to mono full range test chirp with intentions to fix what needed fixing not knowing how psychic the program was...I was foiled
The 5 inch peerless is covering the same frequenies as any other sub....so it isn't really a center channel right now.
Ay ideas?
The other deck with PL2 is a JVC AVX2 with DVD-A, and all but those programs only apply to the disc. Since I use my Ipod, mainly, I figure that may be out.
I do, however, own a laptop and a 6 channel firewire proaudio interface by presonus...anyway...I DID A DIYMA CUZ I'M A GOOD BOYEEEE!!!!!
I'm not crafty...this is actually very good work for me.
(I intend to replace the ugly screws
Ay ideas?
