I recently built a new sq system in my 4th gen firebird and am unhappy about my soundstaging and could use some guidance. Yes, I know that firebirds/camaros are not the easiest cars for sq, but I'm ok with that.
Details: I am using Alpine's newest Type X ring radiators mounted in the a-pillars facing the inside of the opposite seat (so, they are aimed crossing each other in the middle of the car). The tweeters are temp mounted inside of plastic cups (like a paint can cap) with a swivel mount attached so I can aim them. The cups are mounted as far back against the windshield as possible to minimize PLD from the door mids.
As of this moment, the system is horribly bright and soundstaging/imaging is completely nonexistent. The sound seems locked to the nearest side tweeter. I thought I was on the right track with my idea (I read on this forum how ring radiators are commonly crossed in the middle of the car, the PLD between woofer and tweeter is less then 2" and PLD between driver and passenger is only 12" for the tw and 14" for the woofer - which is just over 1ms. I'm using the included x-overs with the proper alpine suggested phase modules and I have a DSP. I have read about tweeters sounding better mounted in spheres, and tried to come close by using the plastic tops from spray paint cans.).
In my last system, an older alpine type x with silk dome tweeters in the a-pillars facing each other imaged a lot better and were nowhere near as bright.
So, I am wondering where I should start to fix my issues? I would like to know your thoughts on what could be causing the MOST problems - I know the acreage of plastic and glass isn't helping, but the problems weren't this bad with the last tweeters. Are the cups causing more problems then they are helping? Should I carpet my dash pad first? Should I aim the tweeters differently first? Any other thoughts or suggestions?
Much appreciated!
Much appreciated!
