The 4 of them in parallel will give you a 2 ohm load, so something that'll give you a decent 800 watts into 2 ohms. Kicker comes to mind first, just because most of their mono amps seem to be optimized for 2 ohm mono.Ok so i bought a boat and it has 4 Rockford 15" p1 8 ohm rated for 200 rms, so my question is what will be the best way to power these, preferably one amp. Any input is appreciated.
That or something like an Alpine PDX.1000. It might even draw less...?The 4 of them in parallel will give you a 2 ohm load, so something that'll give you a decent 800 watts into 2 ohms. Kicker comes to mind first, just because most of their mono amps seem to be optimized for 2 ohm mono.
Cadence... have a look at thier site and/or contact Jason/paul here (not sure how the exact SN is spelled, put it in search and it will bring up a list of names, use the closest match if you do this)... factory direct..Is there a decent budget brand out there? hifonics? MA audio?
