DS-21 said:
If that is the case, then the obvious answer is that you're looking at the wrong graphs, or not knowing what you're interpreting.
No, the obvious answer is that I gave my opinion of the Utopia based on a complete setup. A referrence vehicle that YOU have yet to listen to... actually 2 of them. I did not look at any graphs or tried to interpret anything in this case...
The car sounded phenomenal, despite the fact that the said drivers happen to have "higher distortion measurements" when compared to others. In both vehicles the 5" Utopia was used as midrange & one with the 6.5" was used for midbass duty while the other used 8" OZ free air subs for midbass.
Now without you as so much as having a damn clue of how good or bad the vehicles sound, you quickly dismiss what I posted because you have seen graphs???
You see the car environment is not consistent. Nor will you be able to duplicate your measurements outside the car with the drivers installed in it. It really serves as a great equalizer & all drivers perform much worse in it, thus masking what you might get in graphs outside of the vehicle. Imagine that... the great DS-21 actually has his favorites in his car & hears no distortion from them... yeah in your dreams pal... Your ears are no better than anyone else, don't flatter yourself... your lack of insight of the car audio environment is obvious.
