ib setups most of the time will not have the same output as putting a sub in an box. they tend to to have lower power handling also. they need to be sealed really well a lot of times there are holes that u dont see until u start looking hard.
"-Plays from ½ ohm to 4 ohm Stereo Loads"Do you have a D2 vc sub? If yes, try to check your wiring... DC Refs are only stable to 2ohm
Hope that helps,
Kelvin
PS: everybody can mess the wiring up... Try to check, you never know
Ill try that and see what happensNo, the HP is not the culprit.
Look, the only thing that would put that sub into protect would be low speaker impedance. Try seriesing the VCs and changing the Z switch to High and see if the problem goes away (YES, I know... but try it).
