1 - 6 of 6 Posts
I cant find the spec sheets on the mid or tweet, so whats a good starting crossover when running this set active?
the passive that comes with the set goes as low as [email protected] 12dB/oct. I would use that as starting point.
for the woofer a HPF of about 80 and LPF at the tweeter setting will work.
I'm running the same tweeter (xs28) and I'm using a LP of 3250kHz/24db. Mids aren't in yet but i'll be using the cx62 instead
Sounds good. Thanks
I am sure he meant HP ;)
** Not responsible for you trying to make your 1" tweeters play 30hz lol. **
Oops. Good catch
1 - 6 of 6 Posts
