1 - 12 of 12 Posts
· Registered
Hello everyone,
I am looking to replace my IDQ v.3. I love the sound of the sub however it is not getting loud enough for me at times. I currently have a zapco reference 1100.1 connected to it and if I goo to high on the volume I can hear breakup or clone slapping so I immediately lower the gain or volume to prevent damage. I want to take one of two approaches. First approach being find a comparable sub that I can actually fit in the passenger floor. Second approach is to get a 12-13" SQL sub and leave it in the trunk. Does anyone have any recommendations on similar sound sub that puts out more output? I am thinking of trying out another 12w7 or 13w7 however the last couple of times I had one the lower hz was too much and the higher hz in the 50-80hz wasn't there. This was with the recommended box sizes from JL. I had the JL sealed box and the JL HO box. In hindsight I probably should have tuned them but did not. I do not want to go more than one sub. Any thoughts would be appreciated. Thanks
· Registered
W12GTi, or CSS SDX12. Great reviews on the W12GTi as you know, I'd take that over a Fi Q. The SDX12 is not as known, but looks amazing on paper. The few guys that have run them have been impressed, but I am not one of those guys.
· Registered
I noticed the XMAX on the W12GTI is nowhere near as much as the ID Max. Output alone can the id max get louder than the gti?
· Registered
The idmax will get much loudet than the idq and sound really good doing it
· Registered
IDMAx should get real consideration if you have the power to run it. And if you can wait a couple weeks i will give you my opinion of the CSS SDX 12 in a small sealed box off 500 watts.
· Registered
Discussion Starter · #9 ·
VERY interested in how it goes with the CSS. Right now I have a Zapco ref 1100.1 for the subs. But if needed I can move the Zapco c2k 6.0 for subs and use the dls a3 for fronts.
· Registered
Ive used the gti and the idmax and while the jbl sounded great, the max got louder. Keep in mind they were in similar sealed boxes
· Registered
GTI is far superior sub to a N ID Max is. Most disappointing sub I ever owned was an ID Max. Coming from a guy that was an ID fanatic... I think mine was a V2. Went back to my IDQ's. And the Xmas on the GTI is nowhere near an ID Max?
GTI gets plenty loud.
· Registered
Discussion Starter · #12 ·
Years ago I had 2 version 1 idmax 12's in a sealed box. They sounded pretty good but I always felt something was missing. Each one had about 650 watts a piece.
1 - 12 of 12 Posts
