1 - 13 of 13 Posts
no woofers please i got them everywhere
a small mono amp 250-500 watt would be better
i mean small in size i want to mount them under my seat in my car
i can add $ on my end if it fits the bill
Discussion Starter · #8 · (Edited)
no just one pair i was just using pics i had snapped already
the square cut minibodys the cuvved ones are for my car and the fullbodys are too
i would assume they are a modified /re-badged selenium compression driver if i remember correctly,although don't quote me
it should work with any screw on or bolt on 1" compression driver under about 4.5" in diameter, to use the screw on you need a 4$ adaptor
for the bolt on just the bolts that fit the driver
in this pics there is a reference next to the cheapie 14$ compression drivers from parts express
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-225
this driver would not fit it would hit the body and you can see the mating flange would be usable for an adaptor or a bolt on driver in that pic too
1 - 13 of 13 Posts
