1 - 10 of 10 Posts
I have a set of the Boston Pro 50 comps and one of my tweeters is shot! When i read it with a DMM, i get nothing. The other is 6.7ohms. (so I'm assuming they are 6 ohm tweeters) Could I simply replace the tweets with other 6 ohm tweets and keep it movin? and if so, what tweets would you recommend? Trying to get best bang for the buck here as I'm already over budget with this setup.
Discussion Starter #2
or should I be looking at the DC resistance as opposed to the nominal impedance?
since I'm getting no resistance from the tweeter as opposed to a reallly high one..is it possible someone could fix it?
also if anyone has any of the type m2 tweeters from the pro50 or pro60 set they are willing sell I may be interested or maybe other 8 ohm nominal tweets with a DC around 6.7
bump , ok so does anyone know of a 6ohm nominal tweeter with a FS around 1400hz?
we did an impedance sweep and this will fit the passive xover best.
Bump need a 6 ohm nominal tweet with an fs of 1400hz
1 - 10 of 10 Posts
