That's right. Bing can no longer pick on me for not writing any build logs. My first! (Well, not counting my first fake build log (that might I add, had a number of pages of worthwhile content! lol..)).
This build was for a previous customer.
http://www.diymobileaudio.com/forum...l-sony-jbl-seas-mosconi-stereo-integrity.html
This time around the plan was to upgrade the processor from an MS8 to a Mosconi 6to8v8. While the MS8 was a capable processor, the source unit this time was going to be a tablet, not a traditional radio. To maximize the sound quality, the audio was streamed directly from the tablet to the AMAS unit installed in the 6to8v8. The dash also had to be reconstructed to not only hold the large tablet, but also accommodate a variety of gauges and controllers.
So, let's take a look at the final result!
First up, the closeup of the tablet:
Now, let's see a wider view of the dash:
A little lower shot of the dash:
And now the console:
Cool, right? But wait! There's MORE! The client wanted access to 2 additional gauges, so we found a spot for them behind the tablet.
In the back of the car Bing freshened up some of the original panels with new carpet and the top trim piece was modified to frame the 6to8v8.
Let's take a look at what it took to get that massive tablet in the dash! It was kind of like playing one of those sliding number square games with all the pieces to see how it could fit!
I started with cutting the HVAC control piece out of the top section of the dash. Then I cut out the Hazzard button area. I temporarily attached the piece with CA glue, making sure it was level and square in the opening. After it was secure I heatwelded it together from the back side. This will ensure that the piece stays looking good for years to come. With the HVAC section secured I moved on to the Hazzard switch piece. Again, I cut, temporarily secured with CA glue, and then heat welded.
With those piece affixed I moved on to the mount for the Mosconi DRC controller. It was a very tight squeeze between the side and the Hazzard switch, but it fit! I made a plate out of ABS with the cutout for the knob bezel and the display. I also added 4 mounting points for the controller and countersunk the screw holes for it
Next was working on the actual tablet mount. I cut the remainder of the upper dash piece out to fit the space I needed. Then I constructed an ABS housing out of 1/4" ABS. I CA glued and heat welded that housing into the opening. This was the base for the upper tablet install. With that base mounted I started working on the trim pieces to frame out the tablet once it was installed. I stared by making two pieces out of 3/4" acrylic. I chose acrylic to make the frame because I knew I could securely fasten the pieces. The trim is a "U" shape and if it was made out of wood it would be too fragile. I was able to drill and tap the acrylic and not only glue but also bolt the pieces together.
With the "U" frame finished I decided to add in 2 little trim pieces to flank the top exposed sides of the frame. I used these pieces to tie the frame into the dash visually. The would also mold sloping forward and down on the dash bezel giving the pieces the illusion of blending all the pieces together coherently.
Behind the tablet the client wanted 2 gauges. To accommodate the depth of the gauges I had to space the gauge mounting plate back 1/2". I created a shape using my new Sonus EVOL kit and cut the shape out with the router. The gauge plate would bolt from behind so I added 4 threaded inserts to the wood piece. With the inserts in I glued the piece to the of the housing. A quick pass with a top bearing flush cut bit on the router and I had a perfect opening.
Hole cut, it was time to move on to filling the gaps left by the HVAC removal and start smoothing out the piece.
After the cosmetics were taken care of it was time to address the mounting of the trim piece into the car. I made some modifications to the OEM metal structure that would allow the pieces to bolt back in using the OEM mounting spots.
The final part of the front fabrication work was to mount two control units in the console. I started by making a framework that would old the two units and attach to the underside of the console. The taped spot in the picture is where an upholstered insert will be glued. I wanted to keep the wood clean so the glue would adhere well.
The piece ended up being fairly modular. The bracket that sandwiched the back controller was also the bracket that held in the front controller. I also made a metal mounting bracket to help tie the piece into the OEM plastic console.
Enough with the back side of the console, let's see the front!
And, now with the front controller.. (notice the little insert behind the back controller, that is a vinyled rest for your hand when it is using the controllers, this is the spot that was taped up in the first console picture)
Then, it was on to paint!
I decided to add in a little insert on the "U" piece to just add that little extra detail to the piece. In addition the sides and back of the "U" were covered with a short nap felt. This will protect the dash piece when it is removed to take out the tablet. The area surrounding the gauges is also covered with the material to protect the back of the tablet. The "U" piece has magnets imbedded in the top and bottom to hold it onto the dash.
And then a shot of the back of the upper dash piece before assembly. I made a template of the gauge mounting plate that was given to the client. That way if the gauges are ever changed he will be able to have a new plate made.
Sadly, after all the talking I do to Bing about how build pictures are vital to our business, this is the only picture he took of the trunk remodel.
Overall this was a very fun project. It was back to back with a tablet install in a is250 (build log coming soon..).
