So.... they're dual 4ohm, correct?
The statement about a ported box is a myth.The 1000 watts rms at 4 ohms is correct, that was just an error on my part. With the build a box I had the installers also put that together. I've heard a lot about how fill can affect the sound so I could definitely look into doing that. Not having experience building boxes what would your suggestions be to add it? Also, I've heard a ported box would take away from the "punch" affect the sealed boxes create. What are your thoughts on that with this set up? Again I appreciate all of your thoughts!
I'll answer the first part. Polyfil converts sound energy into heat. Unfortunately, the effects of polyfil are usually minimal and borderline psychoacoustic. That goes double if the enclosure isn't properly sized to begin with.I just have two other questions now. What affect does the fill have? And where could I go to get the box tuned and the Q of the system tested?
