1 - 20 of 638 Posts
With enough questions around about how to mount horns etc...
If you have horns installed, please post pics.
If you want to post a couple pics of the install process, thats cool too
I'll Start
Version 2 of my Integra Install from around 2001
Image uploading. Refresh page to view
Most Recent version of BMW Install-MECA Finals Champion
BMW Install -IASCA Finals Champion 2005 (debut of the car)
Winslow's (hatedguy) install from 2001 IASCA Finals
My wife Lori's Install from her 1st IASCA Finals in 2001 (4th place)
Horn is a mini Tractrix horn, one off design, loaded with ID NX30 Tweets
CD1PRO on mini-bodies.
B&C DE500 on ID full size.
Modified full size ID bodies.
These are what I have tried just in this truck.
Alternative to underdash horns. Waveguides on the dash using the BMS 4540ND.
Mounting Horns in my old Eclipse
1/4" Steel L bracket held in place with screws and panel adhesive
Thick backstrapped used to support inside of horn
pass side L bracket
mounting hardware
Driver side horn mounted
pass side mounted
Moderator
I have a few more of the Accord that I can post up...including some cutting of the inner fender to get the compression drivers partly outside the car.
Discussion Starter #12
Special built midbasses on top. Motor from Illusion Nd-12 on IDQ8 drivetrain.
Below is a Genesis version of the 5" Revelator.
yeh what he said. the 8s were badass but having kids is expensive so they were sold a few years back to someone on this forum.
yeaaa. i almost bought them. but i had regular IDQ8's so i couldnt trick myself to doing it :mad:
Quite an interesting read on the HOMster there, but it gets way over my head really quick. Interesting though... might be able to reproduce his results without even having the knowledge/experience to back it up. Thanks Patrick for a wonderfully-documented experiment!
Moderator
Not for the taint of heart when it comes to cutting metal.
First picture is of the old CD2 driver poking out of the fender well of my old Accord. These were on minibodies and I would have put them further back (actually had the horn body outside of the car) but this is as far as I could go without rubbing my tires during a lock to lock turn. The white stuff you see is the paint and primer that I ground away. The entire area was taken down to bare metal. It was later painted black to blend everything in and prevent rust.
Next I tapped the motors up really well. Waxed the tape a few times with mold release wax. Then as a final precaution I spray glued the trunkliner to the motors. The spray glue served two purposes- to physically hold the fabric in place while I mounted the drivers and being petroleum based, the soon to come resin would cause it to peel from the tape on the drivers. So that got saturated with resin. There were no dry looking spots left.
Third picture is the same motor with a few (lol) layer of glass on it. I think it ended up being almost a half inch thick when it was done.
And after it all dried for a few days with the motor in place to prevent shrinkage, I pulled the motor out of the mess. And I was left with a perfect mold of the motor to rest on sitting outside of the car.
I think this was like 2003 or late 2002 when I did this.
Discussion Starter #18
i kinda thought it before but now i know it... you are CRAZY :)
pssst , thats nothing...look again at the pics of the horn install in my Eclipse
anything look "different" about the Clutch location?
Discussion Starter #20
But wait, there is more...loL
Never before posted pictures of a couple dash rebuilds that never saw completion.
break out the idq10 in the glove box!!:D:D
1 - 20 of 638 Posts
