Yo
The VW GTI interior door panel ~6" opening has these "teeth" on it. I plan to use Sound Skins speaker rings (CCF) between the GB60 woofer and the door panel, but do I leave the interior door panel as is?
I removed the cheap VW foam that was glued to the opening "teeth".
Would it be better if the thin surround (with the teeth) was made wider with bondo/CLD? Or leave as is (simply stick the Sound Skins speaker rings to the surround teeth)?
tnx
tnx
