1 - 3 of 3 Posts
Ok im going to start an ipad for the G6
I'm looking to either wire my ac controls to the center glove box im goin to need wire im looking at 20 ga to 14 wire im guesstimating 4 to 5 feet of wire i probably use speaker wire to save cost
as always any thoughts ,ides and ? is welcome
I'm in the planing stage
Sent from my iPad using Tapatalk
You'll need about 2 amps at 5volts for the unit.
I'd run 12 volts to a USB charging unit. There are a bunch of them out there, but you need to make sure that the adapter puts out at least 1 amp to run *or* charge the iPad... 2 amps to charge and run.
Here's one that you could run off a hard wired 12 v socket in your glove compartment:
Amazon.com: Griffin Technology PowerJolt Plus 2 amp Power Charger for iPad, iPhone and iPod (Black): Electronics
It would only pull a little over 1 amp from your electrical system, so you could run 18 or 16 gauge wire to the socket.
You can tap the headphone out for audio.
Well I'm got everything I needed to to get power to the iPad and as for audio I'm using the aux output of my 360.2
But that wont won't work I have an all in one cable that has RCA USB plus I'm only want to used one cable
I was thinking using 18 ga wire to extend the ac controls
1 - 3 of 3 Posts
