Well, then that's your limit.I set the gains with HU @ 32...I can barley get past 28 when the speakers just SCREAM
Then turn your gains down. What is the max volume of the head unit? Loud listening should use the majority of your head unit’s volume. If it’s 28 out of 40 and it “screams” then your gains should be lowerThanks...turned it back just a touch.
Interesting...I set the gains with HU @ 32...I can barley get past 28 when the speakers just SCREAM
This isn’t always 100% true especially when you’re using different types of music sampling rates and bit depth and bitrates which changes the dynamic range and give you different volume listening levels especially when your into high res vinyl rips or dsd stuff.Then turn your gains down. What is the max volume of the head unit? Loud listening should use the majority of your head unit’s volume. If it’s 28 out of 40 and it “screams” then your gains should be lower
You understand that clipping blows speakers but so does heat and you don’t need to clip to build more heat and heat is generated thru amps volts wattage I’m saying them all to avoids these trolls.The HU (Kenwood Marine) goes to max 35...checked it with the O-Scope and it went to 35 with a clean signal, so I set my gains @ 32 volume. My gains are set based off my O-Scope, so if I was to lower them just to get my HU to play @ 32 would be counter intuitive, no?
When I say the loudest I can get it is 28 and they scream, that's in my garage so it doesn't really count. On the road, with all the road noise, exhaust and wind, I don't know if 28 will get loud enough...so there is still 4 more notches available. With that said, if I go up to 32, I will be pushing way more wattage to my speakers than the manufacturer suggest amount...but it's verified clean so the odds of blowing my speakers should be low...right?
I can always play around with the xover, slops, and other options within the deck to fine tune I suppose?
I’m guessing it was 1.12khz as it says it on the scope displaySilly question fastsoup, but when you were testing the Kenwood with your o'scope where playing either a 1KHz or 50Hz non attenuated tone through it?
Interesting though since if it was a 1KHz tone being played that his device is showing 1.112KHz. I know it is just off a bit, but the screenshot I posted was taken with just a little DSO nano when I was testing my home speakers, and it is dead nuts on 1KHz.I’m guessing it was 1.12khz as it says it on the scope display
Hey guys...setting gains on the 800.4 bridged/bike not running...I get some static before the wavelength "flattens" out...is that considered a clip?
Does it read somewhat off when testing other tone values?
The speakers are Ground Zero Gzcf & amp is a SounDigital 800.4evox bridged- rated for 150wrms...but guys on the Harley Forums swear the speaker love the 200-250 range so that's where I set them (225)...but I bet @ volume 28 it's going to be significantly less.No your gains are set correctly so don't touch them now , what you are describing is what happens to lesser quality drivers or amps when being pushed , their sound changes (harsher) as you get near the limits , to me this is a sign of how good a system is when the sound doesn't change when it's turned up loud.
That's distortion, both what you see on the o-scope and what you hear (the scream).Thanks...turned it back just a touch.
So what you are saying is that even tho volume 32 is not clipping, and is 30v (225w), my speakers are screaming help at volume 28, which is a substantially lower wattage. These Ground Zero Yellow Baskets have a good history of guys throwing 250wrms at them and they sound fantastic...I swear there is a defect with mine from the factory.That's distortion, both what you see on the o-scope and what you hear (the scream).
Just curious, is that a class D amp? You mentioned a bike, so I'm guessing it is. And, what brand?
Nevermind, just read the whole thread.
Your speakers could also be complaining about all that power.
