1 - 7 of 7 Posts
Is there difference help?
is there a difference between a subwoofer of 8, 10, 12 or 15 inches
With reference to the sound quality, notes or frequencies themselves, if they are of the same brand and series?
proper power, box, setup, no there is not a difference you would hear.
except volume, bigger will put out more SPL with the same wattage.
All else being equal, bigger will be more efficient, more linear, have less distortion, and a flatter frequency response.
I will always run the largest sub I can fit or multiples of large subs. The only downside is the space taken up and that can be nearly eliminated by going IB.
Of course, there are exceptions to everything.
size, price, space requirements, qts, qms, sd, qes, vas, fs, depth, width, tuning options, electro mechanical alignment, required power to get equal spl, should i keep going?
thats like asking:
Whats the difference between a ford, subaru, audi, ferrari, and pagani.
thats like asking:
In the same series, assuming the ts parameters are similar or as I said two subs that are identical in every way but the size, the larger one is going to be better in every way.
1 - 7 of 7 Posts
