Step-by-step mating spacers for door speaks - AcuraZine Community
Curious if anyone on here has done thing or a combination of this and sealing up the access holes, although that's probably redundant
The reader's digest version:
"The purpose of mating spacers is to mate up to the rear of the door panel, the way the factory speaker frame does. This allows the whole door panel to be the speaker's "baffle".
A baffle is the panel a speaker is mounted to. The more a baffle leaks, or the smaller it is, the less mid-bass can be played. The metal skin inside the door is very leaky, and many people respond to this by sealing up all the holes with a big sheet of Dynamat. This makes the speaker sound better, but also covers up all the bolts needed by mechanics if anything ever breaks or you get hit. Also, it adds more weight than you need to add.
The mating-spacer solution sounds better because the speaker is firing directly through the door panel hole into the cabin, instead of into a chamber with a hole in it (the chamber is the space between the door panel and the door). Much higher-fidelity sound is possible this way."
Just curious
Just curious
