1 - 15 of 15 Posts
This is only a stop gap until the audiofrog 8” come out. I’m running the hybrid u69s 2ohm right now. I just thought I would give the 4ohm full version a go.
Maybe. I’m picking it up from audio x on Monday. Just had a full trunk build as well as tune and pillars done. Steve keeps telling me I’m not going to want to change anything but we will see. I told him those frogs were going in one way or the other but he just laughed it off. I’ll take a look at those 8’s you have though and check fitment
How do you like the 2 ohm u69s? I'm def looking forward to the 8" frog but it being d2 means I'll have to upgrade power unless a d4 version is released.
They are nice no doubt. Before I had them I had gb60’s. The rest of my system is audiofrog gb series. For some reason I wanted to see what 6x9’s could do. That’s what my stock is. The gb60’s pounded but there is something about the extra cone area that I like.
I hear you about the cone area. Its most likely the u69s 2 ohm or sa mb-8 2 ohm at this point.
Reactions: adrian s
Absolutely. The best I’ve heard yet as far as midbass are the morel 9’s. Scott Brazelton’s car has them and it’s ridiculous. Strongest midbass I’ve ever heard by a long shot
I currently have Audio Development W800’s and I am very pleased, they are also midbass monsters, I have yet to hear the Morels
Discussion Starter #13
The neo’s were at the top of my list. I even purchased some but they wouldn’t fit. It wasn’t the depth , it was the basket shape. That’s why I’m hoping the af 8’s will fit. They have a basket that looks very Accommodating for my install. But yes I’ve heard great things about those w800’s
Don’t bother swapping between the u69s and the u69... if installed in a door or IB they're very similar, I have just done the same swap but only so I can run my sub off the z150.6ap and use an st-4 sq bridged on my midbass As the st4 isn’t two ohm stable when bridged 👍🏼
I would always take a little extra power on midbass so 2ohm wins if my amp would take it
Discussion Starter #15
my C four does 220 @2ohm and 440 @4ohm bridged. Steve just basically said the same and he’s tuning it right now so I’ll probably stick with the 2ohm. I was just basically trying to see if the extra power would help or not.
1 - 15 of 15 Posts
