for the guys that know me, you will prolly know that for my personal preference, when cosmetics and stealthiness goes up again SQ in the most strict sense, I will personally almost always side with the former. for this reason you will very rarely see me do on axis tweets, or ovely large kick panels with more than two way comp sets, in other words, if an installation method mean that it could net slightly better SQ, but at the risk that it will stand out drastically from the vehicle, iwill usually not do i... I guess its a strength and a weakness depdending on what crowd you ask
So i guess it was refreshing to depart from this value that i hold so dear once in a while. The biggest departure from my norm for this car, was the moldiing of large format tweets on axis on a relatively thin A pillar
acutally it was acutally very relaxing in a sense beucase i just had to follow orders, basically i installed things the way i was told to by the customer and his adviser
so please dont ask me why something was installed a certain way, instead, ask Mr. whatzzap and Senor Eng, as they are the owner and adviser to this build...respectively...
The vehicle is a new general infiniti G35S sedan. Since i have so much experince with the old Gs, it was great to finally get my hands on the new version so i can famaliarize myself with it.
so i will dispense with the normal goals and hwat not, as the obvious idea here is to create a system that sounds very good and look clean...also of note is that Ron provided virtually every piece of equipment and supplies. so any questions on gear choice please ask him hehe...most of his choice was top class, but a few umm...decisions related to wiring...cuased me some grief...more on this later
lets get started...
the signal chain starts wtih the stock headunit, there is as of yet, no way to add a new heaudnit via adapters to the stock dash. So the signal is tapped between the bose headunit and the bose amp. I should note that this isnt hte first install in the vehicle, so some of hte work was already done, including hte signal tapping.
from the stock bose output, the signal goes first through a soundgate LOC, and then into an alpine H701 processor, controlled via the C701 controller. I wanted to install the controller in a location that is hidden, but can be easily accessed to sit back and tune in the front seat. so i came up wtih this mounting.
normally, the controller is velcroed to the arm rest top, out of hte way of all the stuff in the amrest holder:
when tuning, just unattach it, and you can sit back, relax and tune all you want from the seat:
the front stage is a set of Scanspeak Alpine F1 status 3 way comp set. the midbass were installed into the stock lower door location, there was already dampening on the door, quite a few layers infact...so i just made the baffle, ran new wires into the door and put in the speaker:
lets get started...
