301 - 320 of 12539 Posts
I'm expecting an update by the end of next week with some real dates. I'll update as soon as I know.
I'm really sorry about these delays and we really appreciate your patience...OK...off to kick the beehive.
Cool, thanks in advance for the update Andy.
.. I'm just pleased the project wasn't scrubbed. Thanks Andy.. Honestly I'd like to see also some more threads about your (H group) other products in here as well. :D You mentioned balanced capable inputs on JBL and Infinity amps for example. 08 Si Sedan here with diff-balanced.. I'm the guy over at ECA that mentioned it.
All JBL and Infinity amps include differential inputs!
I'll have some news about some additional new products in a month or two...stay tuned...but I'm not going to make another mistake like MS-8. We let the cat out o the bag too early and underestimated the project.
Very Good news! Don't know how similar the two branded car-amps are, reading here and there that they're the same just in different clothing, etc.. I won't speculate though I'd bet they at the very least share design. I'll searchy as it's outside the scope of the thread here though. :) Thanks Andy.
They're both Class AB full range amps and ClassD subwoofer amps all with analog filtering. At some level, one could say that all class AB amps are the same, but that wouldn't be accurate. They're similar, but not the same.
Sorry guys and gals. I've been lazy in posting updates here (and on Carsound). Someone over there asked if it was dead.
It's not dead. It's on life support. We're working on it, but DSP resources are limited. We're actively trying to hire more because there are other DSP projects that are lagging too. Sorry for the delay, but it's gonna be great when it's finally available.
Believe me, I want one as badly or worse than the rest of you because EVERYONE in my building wants one and my fiancee' does too.
I wish I had some decent DSP experience I could offer. :)
Keep us posted Andy. I'd love to Beta test one of these too.
If this thing delivers as advertised and is available some day, I am totally building a system around it in my Grand National. Which leads to a question about center channels...
Is it practical/worthwhile to have the left and right fronts running, say...100W and be able to get good results from a center chan. running off of the 20W coming out of the MS-8? I'm really curious about this as the need (or lack thereof) for another amplifier channel to run the center is something of a break-point as to my amp setup. The idea of a balanced soundstage for both driver and passenger is appealing to me.
I've also been kicking around another (maybe bad) idea about doing something similar with midbass. What about using a low powered mid-bass in a "reinforcing" role? Like, rather than have a distinct cut between the midbass and midrange, tune the midrange and sub closer together using the low-powered midbass to sort of help smooth the transition by adding some extra db in the 80 - 200 range, but blended with the midrange more than one would typically do in a 4-way active setup. This would also mean less "violent bass air" bouncing about in my 21 year-old doors. Like, maybe something that would perform decently well with say, 20w in a very small sealed enclosure. Maybe a fiberglass replica of the factory speaker pods mounted on the doors... Anything that potentially lets me get away with more deadening is of much interest to me, as the car is also meant to be very fast; in other words, I don't want to add any more weight than I have to.
I really am looking forward to the potential of this product and am kicking around a lot of ideas trying to come up with the sound I want, given the compromises I need to make. (namely weight)
Thanks for all the info in here and in advance for anything more.
Oh, and BUMP! ;)
I don't recommend either of your ideas.
first, in any system that uses some active center channel processing, whether it's discreet or a matrix or any other extraction method, the center channel becomes the primary front speaker. Most of the music in popular recordings is placed in the center and it needs to be able to play as loudly as the rest of the front speakers and hopefully with the same or similar frequency response.
Midbass speakers tend to be less efficient than midrange and tweeters and always need more power. Plus, if you look at the frequency distribution in most popular music, you'll find far less high frequency info than low frequency info. The midbass frequencies are pretty critical and that would be a nasty place to run out of power.
My suggestion? Use plenty of power on the fronts and use the on-board power for the sides and rear.
20 watts and a small sealed enclosure dn't go together for midbass. You'd be better off installing a seriously efficient instrument speaker and crossing it over with a steep slope at 70 or 80Hz. If you have 5" or 6" speakers in the front, don't bother with a separate midbass.
Andy, work the magic and get this thing out!
PS- But don't rush it and do what Pioneer did with the Avic F series, and kick out a gliched product just to get it to market.
PPS- Thanks for all your hard work, and keeping us posted!
I'm not quite understanding what the hold up is. Other than speaker level inputs it doesn't do anything the 730 or 701 don't do. The DSP programming shouldn't be a big deal. Or am I missing something?
Banned
From what I've read there is a working prototype as far back as mid-late 2007. So, is this a factory re-tooling issue to support mass production?
