161 - 180 of 12528 Posts
Start a thread in off topic, to see if someone will give thehatedguy a decent computer?
I am sure there would be heaps of them around.
Moderator
<- is the guy who at the time had some free cash for a project and found out the day AFTER npdang sold his carputer that he had it forsale at a crackhead price.
Though i'm not durwood, i personally bought a mobo similar to http://cgi.ebay.co.uk/NEW-MSI-915GM-Speedster-FA4R-Socket-M-Motherboard_W0QQitemZ170193076285QQihZ007QQcategoryZ1244QQrdZ1QQssPageNameZWD2VQQcmdZViewItem?_trksid=p1638.m122 .
You can make your own research, but i personally feel that a Pentium M processor of 1.86GHz and up is minimum for the requirements of audio processing. Also cheap, efficient, low power requirements.
Hmm, not familiar with biostar boards but the price is a little high. Brands I've had good luck with:
ASUS
Intel
Gigabyte
MSI
Most of those you can find for around $40-50. I should make a run to my local tigerdirect and see if they have any intel boards on the shelf. I picked one up from them for $20. The processor I linked is a regular desktop PC CPU and they can be power and heat hogs and might not withstand the car environment. I only linked it to show they are cheap.
I agree the pentium mobile processors are the way to go due to low heat and power requirements which means you can use a cheaper DC-DC PSU and a low noise fan on the CPU. They are reasonabley priced an best bang for the buck.
Here are viable Carputer options.
1) Pentium M socket 479 processors >1.8Ghz $50-100+
2) Socket 479 motherboard $50-100
3) M2-ATX DC-DC PSU $90
Downside-those processors and motherboards are not the best deal price wise
1) Pentium 4 Mobile socket 478 processors 1.5Ghz-2Ghz range-$20-60
2) Socket 478 motherboard $20-50
Best bang for the buck if you can find a used motherboard. This combo will give you the bare minimum for a carpc processor.
If you want newer hardware and want to be a little mroe on top of current tech
1) AMD BE2300 or 2350 dual core processor. ~$100
2) socket AM2 motherboard ~$50-100
If you go with regular pentium 4 processors or AMD (which I DON"T recommend) then you have to step up to a $200-250 DC-DC power supply. Same goes for the new intel duo core chips.
This is pretty far OT, so if anyone is really serious, start up a separate thread and we can talk about other hardware options.
ASUS
Intel
Gigabyte
MSI
I will stress the Gigabyte recommendation. Especially for a audio or home theater application. Most other boards make noise, commonly called "coil whine" or "chirping crickets", when the CPU is at nonzero load. The *only* recent boards I've bought that do not have this problem are Gigabyte boards. The Gigabyte boards are explicitly designed with better power supply components (caps, coils) to avoid the coil whine problem.
$150 > free.
Out here you still have to spend a few bucks either way, and frankly, I'm not spending a ton of time fixing up some old POS computer just to have it die. Like painting a car, getting a new suspension and then putting in a used motor. Not my thing.
Juan
GUYS! REALLY?!
You all are acting like you get your head units for free! I don't think anyone is suggesting that you go and swap out your already paid for equipment for a CarPC...I see that we're saying if someone were to start an install and might consider buying a new or a replacement HU a CarPC would be an option!
How in the world did this get so twisted?!:confused:
GUYS! REALLY?!
The issue isn't the free part, but the feeling that some of us are unwashed masses for not trying it because its see "cheap", "quick", "easy" and "free". I think the word "ostrich" came up as well.
For some people a CarPC is a great solution. I work with a guy who is building a killer one for his car and I've learned a lot from him. But you have to do your process and like anything, you get out of it what you put into it.
I just have an issue with people making blanket statements like the ones that have been made in this post. If someone had said "it's a good amount of work, a good amount of money, but well worth it for those who have the skills to do it", I don't think this thread would have headed the way it did.
Juan
if i may chime in: the carputer is definately superior. after having one in my ride, it feels downright anachronistic to drive around without one but i also understand that it is not for everyone. an 8" touchscreen with a custom front end skin certainly trumps the tiny screen available on even the double din units and i don't miss the esoteric interfaces that are used on most HUs. i can't remember the last time i had to handle a CD in the car and that alone was worth the price of admission. with an effecient dual core cpu and a highend audio card, it would be that much easier to add audio processing to the list of carputer duties. all of this functionality can be attained for less than $1k (depending on hardware choices) and still outperform almost all of the HU and/or external processors i've seen used.
bottom line: using the traditional HUs are like running a set of off the shelf components with the included passive crossover while the carputer is much more akin to an active set up; the carputer is simply more user configurable than any other solutions available. for some of you who love tweaking your set up, the carputer is problably a smaller leap than you would expect.
/sales pitch
I can see that. "Free" was probably not completely true- we tend to get emotional for some things we believe in.:p :D
I can build bare bones systems for people and get the basic software/hardware setup (including windows) if they like. I cannot distribute freeware and shareware though legally, the pay versions yes but they are costly. Also, I'd have to limit support because I know how quickly computer questions can escalate and take up an enormous amount of time-which I have limited time as everyone else. Would this interest anyone?
Again, I strongly recommend moving this discussion to a new thread or a different thread. I'm the one responsible as I instigated the derailing of the original thread.
However, the software costs to get you to MS-8 levels of performance are going to be pretty steep. I would be surprised if you could buy the HW and SW for less than the $1K mentioned. If so let me know because I happed to have a MOBO and processor lying around and I would love the throw it in the car.
Keep in mind I am looking for the following features:
4 way active xover (this includes sub)
Outputs for front, rear, and center
31 Band Graphic EQ for each channel
7 band Parametric EQ for each channel (love the ability to use parametric and graphic on the same channel - which most Car PCs can do)
Time Alignment for each channel
Gain Control (pretty easy)
Added bonus
a good expander
I am not familiar if the MS-8 can do all of these (pretty sure it doesn't do the expander function) but from memory it gets pretty close.
BTW - If someone buys all of my Alpine gear for a good price I'll put the Car PC in tomorrow (otherwise I would just use the PC as a processor - as indicated above).
9861
701
TME-770
DVD changer (don't remember the number)
Added bonus
a good expander
All of the above is quite straightforward. I don't know for sure about the expander, but I'm almost certain you can get all of this for free for a PC with the links that durwood has provided in this thread.
But the MS-8 will do more than this. It provides a proprietary EQ that "is better than a parametric/graphic" in the words of the JBL rep (not sure how much weight to give that yet). And it has an auto-eq'ing function that takes binaural measurements at multiple seat positions and head positions, and has already won several nationwide SQ contests (not sure how much to weight this yet, either). Those are the functions that I think will be difficult to match on the PC side.
Yep on the first part. I use a 64band parametric that is free. You can even switch it between analog or digital mode. It's in the link at mp3car I provided.
Proprietary EQ? Well whatever, sounds like a fancy way of not calling it Room Correction. I personally have not used room correction yet, but there are pay versions like Audiolense or you can use DRC/bruteFIR for free. Again, both those should be in the mp3car link and if you dig aroudn there are guides on how to use it.
that's gotta suck when you buy a new cd...or want to compete.
You can still have a CD/DVD player in the car. ;) :p
I'm sure that he means it cuts down on searching for discs in the car when you already have the music loaded up.;)
I retract the cost statement. I was considering purchasing NPDangs system and remembered the costs of the included SW :(
Durwood you've got mail.
